Author Topic: Anritsu sitemaster S331D  (Read 863 times)
Offline 1VOXTopic starter
  • Country: cz
« on: May 30, 2023, 12:41:16 pm »
I have a faulty S331D. It reports integrator failed at start and VNA integrator failed during self test. When measuring the return loss, I feel it works. You don't know where to look for the error.
Thank you
Offline vishaldotgupta
  • Country: in
Re: Anritsu sitemaster S331D
« Reply #1 on: April 18, 2024, 07:07:59 am »
your unit has faulty RF section.  most probably MMIC is cause of failure in such cases.  is your unit a single port or two port version.  I mean the two port unit comes with internal power meter option and has two N female test ports on the front panel
