Author Topic: LG 32LG5000 no back-lighting after one second.  (Read 4585 times)
Offline taliban_0rTopic starter
« on: April 21, 2015, 07:00:41 pm »
Hello everyone,
I'm a Computer Science student from Portugal.
I've got here a LG 32LG5000 and I will make a list of what's going on for better organization. Then I will ask some questions.
Actually, while writing this I was dismantling the TV and I think I found the problem but I will post it anyway.
  • It displays image for only 1 second after turned on.
  • After the screen goes black but everything else seems to work (sound, remote, front LED).
  • Main PSU fuse is OK (took it off and checked it @ electronics shop).
  • There's a sound (like a switch) coming from a board on the left side (view from back) when the display goes off. (later fount it's the CCFL back-lighting board).
  • EU(PAL market).
  • I've found the service manuals.
As said, I dismantled the TV deeper and as far as I know that left side board holds the transformers for the CCFL back-lighting.
Then I proceeded to light up the panel with my phone LED flash and there was image!
So, the back-lighting board seems to be the problem (not sure yet). Maybe it's the other board that triggers the back-lighting that has a problem.
Questions:
  • Anyone knows if this is a common problem on this TV, brand... etc? Just curious.
  • What equipment should I borrow to test the backlighting board? (to be 100% sure).
  • How do I test this kind bulbs? (CCFL)
  • Where can I get a CCFL back-lighting module from a safe store? That ships to Portugal (EU).
Since this is my first post, my background in electronics is a class I took in a semester where I've learned to use equipment, and learned a bit about electronics itself.
Offline dundee
Re: LG 32LG5000 no back-lighting after one second.
« Reply #1 on: April 21, 2015, 08:02:42 pm »
    Hi!
    You should have a soldering iron and multimeter.
    Probably a protection circuit is turning off the backlight, because of a shorted transformer.
    Check the transformers. If there is one ore more with shorts, you could replace them...[/list]
    « Reply #2 on: April 23, 2015, 07:52:37 pm »
    Hi!
    Thank you for your answer!
    So... there is this brown stuff, doesn't seem it's supposed to be there.
    What kind of products are safe to clean this?
    « Last Edit: April 23, 2015, 07:56:46 pm by taliban_0r »
    Offline dundee
    « Reply #3 on: April 23, 2015, 10:19:28 pm »
    The brown stuff is not the problem. You can clean it with isopropyl alcohol.
    I think one or more of the trafos were broken.
    You have to check the resistance of the coils with a multimeter.
    You can geht them as spare parts here:
    http://www.amazon.de/Inverter-Trafo-4018L-Darfon-Inverterboard/dp/B00MWRK0C2 (Germany)
    //EDIT:
    Checkout this:
    http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=3497
    Secondary Resistance should be 1.10 K and
    Primary Resistance should be 0.5 Ohm
    You can see the pinout of the trafo in the picture.
    « Last Edit: April 23, 2015, 10:27:48 pm by dundee »
    Offline Rasz
      • My random blog.
    « Reply #4 on: April 24, 2015, 07:34:50 am »
    holy crap, thats the price of a whole replacement inverter :D
    « Reply #5 on: April 25, 2015, 09:00:47 pm »
    //EDIT:
    Checkout this:
    The readings I got were:  :-DMM
    ~1.010K Ohm on the primary.
    ~0.5 Ohm on the secondary.
    No shorts found.
    If this is some tiny component on that board I'm f.
    There is one of them that is on the 0.9K (pink @ picture)
    The area marked in RED on the picture above is contaminated with some fluid from that yellow sponge.
    Online wraper
    • Country: lv
    « Reply #6 on: April 25, 2015, 09:11:02 pm »
    You messed up primary and secondary.
    Online wraper
    • Country: lv
    « Reply #7 on: April 25, 2015, 09:18:12 pm »
    Should be faulty with a short in the secondary winding. There must not be any significant difference in resistance among transformers.
    Offline iamdarkyoshi
    « Reply #8 on: April 26, 2015, 12:43:08 am »
    I had an Envision monitor with the same fault, but unbelievably, it turned out to be a CRACKED backlighting tube and it was ARCING TO THE CHASSIS!!!! I removed the tubes and just put a strip of cool white LEDS inside and found the logic line that turned the backlighting on. Works a treat.
