Thanks for your replies.
Armadillo: Thank you for the link, It's a different board to this one, But it sure will give me a good place to start.
I will have a good read over it tomorrow.
I would ideally like to fault find the issue instead of just randomly replacing components.
As I would not of learnt anything.
Here are a few pictures of the board:
Here is a list of the main capacitors on this board:
As said before sometimes the TV will power on fully and work, So I have been trying to test voltages between working and not working.
Also as said before the main relays are clicking on and off repeatedly.
After removing the covers I noted that the 2nd relay (RL101) was clicking on before the 1st relay (RL103).
I would of thought that the 1st relay (RL103) in line would come on before the 2nd relay (RL101).
But from reading the link that Armadillo kindly provided this seems to be normal.
Thanks again for your time.
