Author Topic: LG 55LB620V TV brightness not stable after LED change  (Read 921 times)
Offline nmidTopic starter
  • Country: at
« on: October 02, 2022, 05:18:00 pm »
Hello, a few LEDs were burnt out on my TV, so I replaced all of them with new strips.
Unfortunately, after reassembly I noticed that although the backlight is now working again, it is not stable. The top left LED bar is getting brighter every 2 seconds and then normalizes again.
Here is a video: https://giant.gfycat.com/QuerulousAmusingGossamerwingedbutterfly.mp4
Is my assumption correct that it must be the driver and not the strips? Could it be the half burnt out LED strips caused the driver to have a defect? Do any of you have a suggestion what I could try, otherwise the 70€ for the new strips just to have a defective TV would hurt me a lot.
Thank you very much for any help.
Online eurgenca
  • Country: si
Re: LG 55LB620V TV brightness not stable after LED change
« Reply #1 on: October 02, 2022, 05:26:27 pm »
Could be first led on strip damaged.? Top left corner seems to be dark.
  • Country: at
« Reply #2 on: October 02, 2022, 05:36:36 pm »
Thank you for your reply.
I do not believe, so I tried the LEDs when the LCD was still off and all LEDs worked.
But because of your post, I took another picture/test and noticed that on the left side of the screen the picture is a little stripy. So I suspect it might actually be the LCD itself and not the LEDs. I will try reconnecting the ribbon cables, but I suspect I might have damaged something when dissembling, which would be a huge disappointment.
https://giant.gfycat.com/OrneryCalmCalf.mp4
It's not really noticeable because of compression and refreshing.
  • Country: at
« Reply #3 on: October 03, 2022, 01:27:12 am »
So I am pretty sure it is not the LEDs, when unplugging the left ribbon it does not change brightness and I don't see it from the back as well.
So, anyone has any ideas what I could try? I have tried swapping the ribbon cables, pressing all ribbons and components on the signal board without success. The flicker is in fixed time intervals (~2s).
I appreciate any help. Thanks.
« Last Edit: October 03, 2022, 05:34:06 am by nmid »
  • Country: at
« Reply #4 on: October 03, 2022, 01:29:04 am »
One picture is wrong.
  • Country: at
« Reply #5 on: October 05, 2022, 03:02:58 pm »
I have an oscilloscope if that helps, but not much experience with it.
