Author Topic: Rewiring An Astatic G Stand With A 3 Pin Connector  (Read 454 times)
Offline OokpikTopic starter
« on: August 16, 2023, 01:08:59 am »
I have an 3 pin Astatic G stand that I wish to add a 3 pin female connector to the end of the cord.
The cord has two white wire conductors with shield.
Which wires do I solder to pins 1 - 2 - 3 on the connector shown?
White wire with orange terminal dot to pin number ?
White plain wire to pin number ?
Shield wire to pin number ?
Any help in this matter would be greatly appreciated!  :)
Please see the photo below for additional info.
Online DimitriP
Re: Rewiring An Astatic G Stand With A 3 Pin Connector
« Reply #1 on: August 16, 2023, 01:48:26 am »
astatic  :-+
Below is a G-Stand diagram
It doesn't show the other end of the connector whihch is what you are looking for and it shows a red and white whire as well as a shield.
What-goes-where depends on what the radio expects.
« Last Edit: August 16, 2023, 01:51:08 am by DimitriP »
« Reply #2 on: August 16, 2023, 04:10:05 am »
Thanks for the response!
I also found that schematic but like you stated, it does not include the information I am seeking.
