Author Topic: LG HT355SD - DVD player repair (my first repair attempt)  (Read 2805 times)
Offline MarvinTheMartianTopic starter
« on: April 03, 2016, 05:11:00 am »
G'day all,
I'm about to embark on my first attempt at a 'serious repair'.  :)
We have a DVD player (LG HT355SD) that has been gradually failing in that the sound synchronization is getting out of whack (used to happen if you Pause, then Play and I could fix it by pressing Stop and then Play again).
Last night the 'fix' above no longer works and the synchronization is now always out of whack.  :-BROKE
I've opened the case and done a visual inspection but can see nothing obliviously wrong (there are a ton of electros - Chang brand  :palm:) but none look to be leaking. I've yet to use the ESR meter on any of them.
I next did Dave's "thou shalt test voltages" on the power supply board and the voltages are fine. I haven't tested anywhere else at this stage.
I've got the service manual and am going to see if I can get my head around where this synchronization may be happening, before I test any further.  :-//
This could be a long term project as I learn or ultimately a fail because it is too advanced for me at this stage.
If anyone has some tips or advice, I would appreciate it.
Many thanks.
Edit: Forgot the picture - doh!
« Last Edit: April 03, 2016, 06:40:56 am by MarvinTheMartian »
Reviving my old hobby after retiring! Know so little...only one thing to do...watch Dave's videos and keep reading the forum! ;-)
