Hi everyone, I'm new here and I've got my first question for you: yesterday I've received an LG K10 (4G/2016 model) with broken backlight. Everything else works fine, I can even see the screen and all the icons in the dashboard but without any backlight. At first I thought that replacing the screen was the only way to solve the problem, but before doing so I wondered if there was some component on the mainboard to check (eg. ICs, diodes, smd ferrite beads, ecc...) or something similar to do. Do you know what could cause this kind of problem in smartphones? By googling I managed to find some informations but only about iPhones. Help would be appreciated. Thank you all!
Inviato dal mio iPhone utilizzando Tapatalk
