The three fuses are good. The symptoms are when AC power is applied, the tv never turns on. The indicator LED comes on red, then turns white, then goes back to red. The black relay on the high voltage side clicks. When I push the reset button on the CPU board, it sounds like the relay drops out, then reconnects, so it appears there is some communication between the CPU board and the power board.
