Board number is more relevant, same T-Con's are used on different models.
Before replacing, of course check LVDS cable is correctly fitted.
On T-Con board check power is present before and after "F1" fuse.
If power is present before but not after, look for shorts on T-con then replace fuse.
If power is not present before, look for a defective (P)-MOS on mainboard responsible for power switching.
If power is present after, test for other voltages on T-Con on the larger diodes near the inductors.
