Author Topic: LG PF1000U short throw projector, FM51E chassis  (Read 1247 times)
Offline kirill_makerTopic starter
« on: November 01, 2023, 02:38:49 pm »
Hi!
Maybe there are some users around with experience of LG smart tvs/projectors? :)
I'm looking for a dump for the LG PF1000U projector (FM51E chassis), (NAND Hynix H27U1G8F2CTR SPI_FLASH: MX25L8035EM2I, EPROM 24C256C)
The projector is trying to power on, all power sequence stages are ok.
But, after 5 sec fans are starting to spin at 100% for 5 seconds, judging by the sound, and projector falls into the standby.
The problem turned out to be a broken NAND, as it seemed to me:
[ 0.110000] NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3,3V 8-bit)
[ 0.110000] redirect_size = 400000, redirect_start = 7c00000
[ 0.110000] Loading nand bad block info(00000000+00020000)...
[ 0.119000] Mstar nand-flash partition definition
[ 0.119000] mtd info : # of partition = 23
[ 0.119000] Creating 23 MTD partitions on "NAND 128MiB 3,3V 8-bit":
[ 0.119000] 0x00000000-0x00020000 : "bbminfo"
[ 0.120000] 0x00040000-0x00060000 : "mtdinfo"
[ 0.121000] 0x00160000-0x00760000 : "rootfs"
[ 0.121000] 0x00760000-0x007c0000 : "lginit"
[ 0.122000] 0x007c0000-0x007e0000 : "crc32info"
[ 0.123000] 0x007e0000-0x00800000 : "model"
[ 0.124000] 0x00800000-0x00900000 : "logo"
[ 0.124000] 0x00900000-0x00a00000 : "cmndata"
[ 0.125000] 0x00a00000-0x01200000 : "nvram"
[ 0.126000] 0x01200000-0x01300000 : "user"
[ 0.127000] 0x01300000-0x01400000 : "ezcal"
[ 0.128000] 0x01400000-0x014a0000 : "estream"
[ 0.128000] 0x014a0000-0x01620000 : "opsrclib"
[ 0.129000] 0x01620000-0x018a0000 : "kernel"
[ 0.130000] 0x018a0000-0x03560000 : "lgapp"
[ 0.131000] 0x03560000-0x04fa0000 : "lgres"
[ 0.132000] 0x04fa0000-0x05be0000 : "lgfont"
[ 0.132000] 0x05be0000-0x05c00000 : "tplist"
[ 0.133000] 0x05c00000-0x07640000 : "lgres"
[ 0.134000] 0x00080000-0x000a0000 : "cert"
[ 0.135000] 0x000a0000-0x00140000 : "authcxt"
[ 0.136000] 0x00060000-0x00080000 : "hdcp2"
[ 0.137000] 0x00140000-0x00160000 : "keyrsrv"
[ 0.138000] mod_nand_init is invoked
[ 0.138000] GE driver inits
[ 0.138000] mod_iic_init is invoked
[ 0.138000] model option =0xfc
[ 0.138000] Mstar_emac: [ PHY Addr ] ==> :0
[ 0.138000] Mstar_emac: alloRAM_VA_BASE = 0xA0C40000 alloRAM_PA_BASE= 0xC40000 alloRAM_SIZE= 0x100000
[ 0.139000] RBQP_BASE = c44000
[ 0.140000] [SCALER][000173] _mod_scaler_init
[ 0.140000] [TTX_DRV][00508]init 170
[ 0.140000] MDrv_CC_Init
[ 0.140000] init 172
[ 0.140000] [DEMOD_DRV][00369]init 245
[ 0.140000] [BDMA_DRV][00629]init 251
[ 0.141000] TCP cubic registered
[ 0.141000] NET: Registered protocol family 17
[ 0.142000] RPC: Registered udp transport module.
[ 0.142000] RPC: Registered tcp transport module.
[ 0.142000] Adding user_initcall[0] = 0x803a1314
[ 0.142000] Adding user_initcall[1] = 0x803a1320
[ 0.142000] Adding user_initcall[2] = 0x803a66f8
[ 0.144000] VFS: Mounted root (squashfs filesystem) readonly.
[ 0.150000] VFS: Mounted lginit (squashfs filesystem) readonly.
[ 0.150000] Freeing unused kernel memory: 132k freed
[ 0.204000] SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock19
[ 0.225000] Empty flash at 0x000213bc ends at 0x00021800
[ 0.234000] Empty flash at 0x00023200 ends at 0x00023800
[ 0.242000] Empty flash at 0x00024bbc ends at 0x00025000
[ 0.250000] Empty flash at 0x000271ec ends at 0x00027800
[ 0.250000] jffs2_scan_inode_node(): CRC failed on node at 0x00028fe0: Read 0xffffffff, calculated 0x916f9a2e
[ 0.258000] Empty flash at 0x00029120 ends at 0x00029800
[ 0.264000] Empty flash at 0x0002ab84 ends at 0x0002b000
[ 0.289000] Empty flash at 0x00040878 ends at 0x00041000
[ 0.289000] jffs2_scan_dirent_node(): Node CRC failed on node at 0x000427f4: Read 0xffffffff, calculated 0x2322e93d
There is no epk update file for this device and I've tried to fix dump through Linux jffs2/squashfs mount and check.
NAND has no bad blocks as well.
Dumps: https://mega.nz/file/3J1yHJDZ#gYX0safKW1u3Yo_gnsbBCuU3PY1PjlIz93HhyNDma6Q
Service manual for FM51E chassis: https://mega.nz/file/2I9SDKzK#BaFlP0qXkpq7zOkhHXBPXYT8EzF4nqmZApsiouKRJUA
So if someone can check my dump or share dump for healthy device - I will appreciate it :)
Thanks!
« Last Edit: November 01, 2023, 02:45:24 pm by kirill_maker »
Re: LG PF1000U short throw projector, FM51E chassis
« Reply #1 on: February 19, 2024, 01:19:10 pm »
UP^
