My tv (32lb5820) has this issue where it powers only occasionally. Other times the standby led just blinks. I opened it up, disconnected the main board , probed the voltages and discovered a normal 3.6 volt line. However, when I connect the 3.6v line to the pwr-on line (without the main board attached), the 3.6 v rail drops rapidly to 0 volts before returning to 3 volt and resuming the cycle. Similar behaviour can also be observed on the 24 and 12 volt line.
This leads me to believe that the 12/24 volt circuitry on the power supply is faulty. Something may be internally shorted tripping the power supply’s failsafe. Any ideas where to start my diagnosis?
