Hi ALL, need help please, I have here my LG32lg3000 tv it has not worked for a while, plug into mains, hit switch, red led with come on. press remote, nothing happens, the red led flashes and switches off.
I thought now is the time to try fix it, I have checked the normal capacitors, changed a couple of them, the rest look ok, Ive got constant 5.2 volt from the 2 pins, when I short those with power on pin Im getting nothing from tuner or backlight supply.
I have checked T501, I think that is OK as I have 12v on drain of mosfet Q205 Ive also checked power to PC503, with the 5.2v and power-on pins open, ive got 5.2 volts on pins 1 and 2 of PC503, when I join 5.2v and power-on pins, pins 1 and 2 go low on PC503 as Q202 is pulling it to ground competing the circuit, with my limited knowledge I think that part of it is working ok, what I cant understand is what is happening on the switched side of PC503
Could one of you guys have a look and tell guide me through the next test step please
Thanks
