Hello,
I have a cheap 30A variac that looks like this :
https://i.ebayimg.com/images/g/uxYAAOSw6hNgD8d-/s-l1600.jpg
Unfortunately, I can't seem to get it working. It has a pretty weird failure mode where when I turn the knob below about line (120V) voltage, the varic rapidly draws more current (10-15A) and eventually flips the breaker. Confusingly, it's stable and fine turned all the way up ~ 130V, where it draws a few mA.
I have hot connected to the red input terminal, neutral to black and ground to a chassis screw, with no output load. This is per the instructions and some for a similar model I saw at circuit specialists.
Internally, hot is connected to the variac wiper and neutral is connected to the transformer windings and output terminal. There's a switch and a small panel meter attached as well. It's quite clean, and the carbon brush is in good shape. I've also verified there is no extraneous copper between windings.
Overall, I'm pretty confused, and I'm guessing I've miss wired it or it came miswired. Either way, I would love some troubleshooting advice!
EDIT:
Might be the dumbest person in the history of the world. I have it hooked up backwards.
