Author Topic: LG TV video problem.  (Read 1885 times)
Offline Serge125Topic starter
« on: October 07, 2020, 07:36:23 pm »
Hi all!!
   Ok I just got this tv FREE from someone and he did told me of a video problem and even turned it on to show me and yes it does have a problem. He told me that it worked great the night before and next morning this problem. So can this be an easy fix or.... It's an LG 42LV5400-UB. So any thought or suggestions are welcomed!!
THANKS ALL!!
Serge
Re: LG TV video problem.
« Reply #1 on: October 10, 2020, 04:17:14 pm »
Hi all!!
  Ok here's a video of what the screen does and please let me know if it can be fixed or not, up to now no one commented on this.
https://youtu.be/990e7Mn844c
https://youtu.be/W5ZYmxoIDHI
THANKS!!
Offline Rasz
    • My random blog.
« Reply #2 on: October 10, 2020, 04:46:01 pm »
tcon or glass itself
Offline keymaster
  • Country: gr
« Reply #3 on: October 10, 2020, 04:51:16 pm »
There is a big chance , the t-con board is the source of the problem .
Offline james_s
« Reply #4 on: October 10, 2020, 06:27:11 pm »
That's what I'd suggest too, if you can find a t-con board for a reasonable price there's probably a 70% chance that replacing it will fix the problem.
« Reply #5 on: October 11, 2020, 12:30:51 am »
Ok what would be the 30% part? 😉 THANKS!!
Offline james_s
« Reply #6 on: October 11, 2020, 04:41:11 am »
Driver ICs bonded into the glass panel itself, or possibly the main board that handles all the video processing and input switching.
Offline shakalnokturn
« Reply #7 on: October 11, 2020, 10:21:36 am »
Check LVDS interconnect between main and T-con all the same.
Also check power supply from main is clean when it reaches T-con.
I'd say T-con. is defective because the problem is affecting the whole picture (a defective panel will usually have localised defects), the dark trails on green background make it look like a LCD supply voltage on T-con board may be bad.
« Reply #8 on: October 11, 2020, 09:50:49 pm »
I’ll check it tomorrow if I have time. There is a 12v on one of the pins but the repair manual doesn’t say so I hope that I’ll be marked on the board.
« Reply #9 on: October 13, 2020, 05:54:30 pm »
Ok reopened the rear and this is a 52 pin (very narrow) and nothing is written on what pin does what and even though I do have the repair manual I don't see a 12v just a few 3.3v but how can I check that with the pins so close without touching the other pin close by. Here's where I got the manual if ever someone wants to "guide" me trough the pins.
https://elektrotanya.com/lg_42lv5400-ub_chassis_la12e.pdf/download.html
It's on page 34 for the LVDS pinout. Page 51 for the 12v but where on that 52 pin is it?? Ok maybe I just got it I'll check later on this. I think it's pin 51 with a few caps, hmmmm....
Offline james_s
« Reply #10 on: October 13, 2020, 06:35:35 pm »
I would look for test points nearby, or electrolytic capacitors on the main and T-con boards, those are typically across power supply rails.
« Reply #11 on: October 14, 2020, 01:16:18 am »
Ok I think that I have tracked it down to the t-con 51 pin input from he main board. I have circled it in red and right beside it a fuse, so the 12v comes from main board goes to t-con passes through fuse then to the cap where I should get my 12v, right? And if I do get it then my t-con is the problem because the main is supplying the t-com with the needed 12v and if I get a different reading than the 12v then it's the main at fault.
« Last Edit: October 14, 2020, 01:18:47 am by Serge125 »
« Reply #12 on: October 14, 2020, 06:47:34 pm »
So am I right with what I said? Just don't want to just probe anything and short it. Oh yeah on the sham there is 3 caps and on the photo I just see one is it because there are other t-con models that has one of the 3 caps? THANKS!! ;-)
« Last Edit: October 14, 2020, 06:52:57 pm by Serge125 »
Offline Rasz
    • My random blog.
« Reply #13 on: October 14, 2020, 07:57:33 pm »
yes, you can measure directly fuse on the tcon, not that I give tcon supply any significant chance of being the fault here
« Reply #14 on: October 15, 2020, 07:24:04 pm »
Yep checks out ok for voltage at the T-Con board 11.74v so will order a T-Con tomorrow and hope it will fix this!!
Thanks!!!
« Reply #15 on: October 27, 2020, 06:14:14 pm »
Hi all!!!
   Ok I just installed a new t-con same problem!! So what can be causing this problem?? I'm getting the proper voltage to the t-con so it's something else but what any other suggestions?
Thanks!!!
Offline Rasz
    • My random blog.
« Reply #16 on: October 28, 2020, 12:16:41 am »
glass itself. Either inside the glass, glass-flex bonding or chip-on-flex TAB drivers
Russians are the only ones crazy enough to try and fix at this level without access to factory parts and TAB bonding machines.
https://web.archive.org/web/20161124102815/http://monitor.net.ru/forum/topic375748-0.html
TLDR: rip out LED backlight and power supply, those are handy for hobby projects. For example you could turn this dead TV into big light panel. Rest goes into recycle bin.
