Author Topic: LGP32-11P forced power on  (Read 1596 times)
Offline ionicwakeTopic starter
« on: September 27, 2017, 02:22:46 am »
im trying to use  LGP32-11P for powering a few led lights, a pi, and a small 12 volt audio amp. for the life of me i cant get this supply to turn on. ive tried tieing the inverter on and power on pins to ground individually and together. no joy. this typically works, and the supply worked before i pulled it from a broken tv.any assistance would be very appreciated.
http://i653.photobucket.com/albums/uu252/ionicwake/20170926_201017_1.jpg
http://i653.photobucket.com/albums/uu252/ionicwake/20170926_200956.jpg
http://i653.photobucket.com/albums/uu252/ionicwake/20170926_200948_1.jpg
Offline Toasty
  • Component Level Repair Tech
Re: LGP32-11P forced power on
« Reply #1 on: September 27, 2017, 02:53:59 am »
Photobucket: Please update your account to enable 3rd party hosting.
3rd Party Hosting Usage: 100%
veritas odium parit
« Reply #2 on: September 27, 2017, 03:02:19 am »
Offline Toasty
« Reply #3 on: September 27, 2017, 03:11:41 am »
From cold side ground, (north of the dotted line) find a standby voltage on one of the 2 connectors, P201 or P203. May be 5V-12V, but will always be present when just plugged in.  Connect that through a 150? resistor to Power On.
BUT, it may not stay on since CCFLs for the backlight are not connected...
YMMV
T
« Last Edit: September 27, 2017, 03:53:48 am by Toasty »
veritas odium parit
« Reply #4 on: September 27, 2017, 03:20:55 am »
im not getting standby voltages from anything on this board. which seeing as it was just working is disappointing.
« Reply #5 on: September 27, 2017, 04:00:53 am »
aha! got it. it must have been dropped. the fuse was bad.
Offline Toasty
« Reply #6 on: September 27, 2017, 04:06:58 am »
Good!
Was going to suggest you hook it back up to the TV, but your picture shows we're a bit beyond that point...   ^-^
T
veritas odium parit
« Reply #7 on: September 27, 2017, 04:27:10 am »
the screen and many parts of that tv were kicked in. somebody moved and didn't want to take it with them so they kicked it.   i see them all of the time around my apartment
What a waste
« Last Edit: September 27, 2017, 04:39:48 am by ionicwake »
