Author Topic: light bolt 1 phase connection logical problem  (Read 168 times)
Offline john23Topic starter
  • Country: aq
« on: November 05, 2024, 04:24:21 am »
Hello ,an AC light bolp has needs two wires , while AC power in the wall has three wires.
So how am i supposed to connect the lightbolp in the power in the wall?
Thanks.
Offline CaptDon
  • Country: is
Re: light bolt 1 phase connection logical problem
« Reply #1 on: November 05, 2024, 01:16:15 pm »
It is so obvious, The lamp gets connected to the brown (hot) and blue (return) and if you have a metal fixture the green (earth ground) goes to the metal frame of the fixture. If this wasn't obvious to you from the start then let someone else do the wiring.
