Author Topic: liitokala charger  (Read 1244 times)
Offline m3vuvTopic starter
liitokala charger
« on: December 03, 2020, 06:15:16 pm »
hi all ive a liitokala lii-500 charger thats died,does anyone know where i can find a schematic for it?,cheers Paul m3vuv.
Offline shakalnokturn
Re: liitokala charger
« Reply #1 on: December 03, 2020, 08:21:30 pm »
No schematic, I have the same charger.
The 12V adapter supplied with mine went intermittent very soon.
Have you checked yours?
« Reply #2 on: December 03, 2020, 09:24:36 pm »
yup my adaptor is fine,just the charger wont power up
Offline Miwer
« Reply #3 on: March 07, 2021, 11:17:36 am »
I have one of those too. Also looking for a schematic.
Mine died after being dropped on the floor from a table. I replaced a TL431 vref and a transistor on the power input to make it work again, but now it seems a bit "wonky" as it does not correctly measure the voltage on the batteries. I can't seem to find any other faults on it, but it's not easy without a schematic. No visible damages, but I'm not sure if the drop could have caused a pcb via to crack, and make bad connection.
Offline Miwer
« Reply #4 on: March 17, 2021, 10:24:49 am »
Just wanted to follow up on this, with some pictures.
You need to check the voltages around U2 and Q27 - you can see my measurements in the pictures. The 5v regulator in this charger is more or less directly copied from the TL431 datasheet (apart from the resistor values).
I had to change both the TL431 (U2) and the NPN transistor (Q27) in mine.
Now beware - the chinese "431" marked part is actually not pin compatible with the TL431 from Texas Instruments, that I had. The pinout actually matches TL432 instead, so I had to flip my TL431 around, and connect a wire from anode to ground, as you can see in the picture.
From the datasheet: "The TL432 device has exactly the same functionality and electrical specifications as the TL431 device, but has different pinouts for the DBV, DBZ, and PK packages."
If I had to purchase a replacement, I would get the TL432 instead, but I already had the TL431 so I couldn't be bothered.
As for the NPN transistor (Q27), I believe any generic NPN transistor will work, as long as it can handle the current draw of the Liitokala (only the logic/display/etc., not the charging) - I just used whatever high current NPN transistor I could find. In my case I used a ZXTN19100CFF - maybe overkill, but it works.  ;D
