Author Topic: Bump: Substitute line filter for HP54201A  (Read 1759 times)
Offline Lorenzo_1Topic starter
« on: December 20, 2023, 01:14:42 pm »
Any suggestions for a suitable replacement line filter?
Trying to find a replacement line filter suitable for an HP54201A oscilloscope. Was getting it ready for disposal - figured it might be a useful first scope for someone starting out. It's been in storage for over a year.  Booted up and self-calibrated OK but after about 15 minutes it blew lots of magic smoke.  However, it continued working till I cut power and is seemingly still functional. Turned out the Schaffner line filter has let go. Easy clean-up and no evident harm to PCB. Perhaps I should have brought it up to operating voltage more slowly with a variac?
Can't find any spec sheet or details for the fitted FS 2150-6-07 apart from schematic and specs on the housing (photo attached) or anything in the FS series. Can anyone suggest a suitable replacement?  I had a look at the current Schaffner range but couldn't confidently work out the right substitute. Perhaps an FN9233 series would suit (https://www.schaffner.com/product/fn9233)?
« Last Edit: December 22, 2023, 12:13:00 pm by Lorenzo_1 »
Offline Haenk
Re: Substitute line filter for HP54201A
« Reply #1 on: December 20, 2023, 03:07:57 pm »
You did nothing wrong, even ramping up the voltage would have blown it up.
Post mortem fun: 5 bucks on "blown RIFA cap inside" :)
Offline Stray Electron
« Reply #2 on: December 20, 2023, 07:14:49 pm »
  FYI another thread on the same model scope https://www.eevblog.com/forum/chat/hp-54201a-digitizing-scope-worth-buying/
   My first DSO was a HP 54501A.  I still have it, it still works and I still use it on occasion.  Great scopes IMO.
