Author Topic: Linear Power Supply Problem - HELP!!!!  (Read 3366 times)
Offline jaunty
« on: September 26, 2018, 04:44:28 am »
SO - I hope this isn't uncouth to do but I thought it would be good to start a new thread - though i started a previous one here  https://www.eevblog.com/forum/repair/bjt-replacement-pulling-my-hair-out/
under different auspices ... and starting with different questions - so really the problem is now completely different. I hope that's cool with you folks - i just thought that continuing under the 'older' thread would be confusing since there were a few false assumptions i'd made etc etc ... so this would be a clean slate but I am in need of help now more than ever ... so i am at your mercy folks ...
SO - i have this 1974 era Yamaha Synthesizer (like a big organ) - you know the soundtrack to blade runner? that was the big brother to this one. ANYWAY - it was working just FINE until one day i turned it on and popped a fuse (F1 in the diagram). So after removing the PS from the keyboard assembly I did lots of reading etc while i waited for the parts to arrive (I figured i would do a complete rebuild - mostly) - ok - well i ended up just changing all the electrolytics on board primarily - and i changed one 2SA490 that i inadvertently pulled a leg from. SO ANYWAY - now - having HOPED that the problem was one of the capacitors that had gone dopey after so many years ... i tried (without success) to start it up again ...
symptom 1: there is an open load across the hot and neutral of my power cable.
symptom 2: when i apply power with no load the dim bulb doesn't even light - and I measure the voltages/resistance thusly (see diagram linked) at these points.
symptom 3: when i apply power when it's CONNECTED to the boards downstream IN the keyboard ... the dim bulb becomes a very very BRIGHT one and stays that way (so i try not to keep it on too long!)
here is the circuit diagram and relevant (I think?) measurements:
so - what do you think??
I thought it was a blown primary for a bit but it doesnt' seem to measure like it ... secondaries SEEM to measure fine (as indicated). I'm just scratching my head here - I can't seem to get any voltage into the reservoir caps ... could it be these confounded SCRs?? But even so - I should think I'd be getting a much higher reading pre-SCR (?) or is that the result of having no load across the outputs?? Should i try to attach a dummy load?? (it's a bit tricky doing that however because of the sense lines imo).
or could it be some kind of monkey business with a bad X-CAP?? (at left on diagram) what would cause such symptoms?
Thank you for reading this ...
Jon T.
« Last Edit: September 26, 2018, 07:03:03 am by jaunty »
Offline jaunty
Re: Linear Power Supply Problem - HELP!!!!
« Reply #1 on: September 26, 2018, 07:04:46 am »
quick update - looks like those aren't SCRs but just dual diodes - so no 'control issues' i guess ... AND ... i traced through from the hot to neutral pins of the power cord and indeed it's ONLY the X cap which is blocking the continuity .. hmmm ... shouldn't that be normal or shouldn't the X cap normally be ACROSS the power input?
Offline CJay
« Reply #2 on: September 26, 2018, 10:04:47 am »
You seem rather confused.
Go back to first principles, disconnect the transformer secondaries and measure the output voltages.
The following users thanked this post: jaunty
Offline jaunty
« Reply #3 on: September 26, 2018, 10:29:41 am »
well that's why i'm trying to look at this simply now ... and just look at 'evidence' only - so to me it says there's a problem with the primary somehow ... you probably looked at the old post - in which case i might not blame you for thinking so - but that was a whole other topic .. about replacing bipolar transistors .. and it morphed into something else ... so i spent some time looking at the power supply problem I started with and set it up as cogently as i could.
at any rate ... i may well do that though it will require severing all the cables going down to the board in order to disconnect it - so it's like four hours of work which (understandably) i'd LIKE to avoid ... anyway
« Last Edit: September 26, 2018, 10:55:20 am by jaunty »
Offline Armadillo
« Reply #4 on: September 26, 2018, 11:02:23 am »
Your primary wiring looks open circuit.
The primary connection is not clear and incomplete in the diagram. And your dimmer wiring is unknown. You should use a incandescent light bulb 40W type instead if you meant to connect it in series for testing purpose.
Why don't you try alternative primary [if it is not used], by connecting ac input power onto BE and RE instead? [if it was designed as primary].
Offline CJay
« Reply #5 on: September 26, 2018, 11:59:41 am »
Nope, I was only referring to this post.
I don't think I read the other one (I may have).
You need to verify the transformer is working before you go any further because your voltage readings suggest it's got a problem.
Offline coromonadalix
« Reply #6 on: September 26, 2018, 12:00:52 pm »
I have drawn red circles where normally you should isolate the regulator sections,  does your (15 and 15s) and -15 and -15s) pins are connected together ??  The S lines are normally senses line ...
The green voltages values on the x-former secondary side are definitely wrong
Have you tested the main capacitors for shorts leakage, esr, and bulged tops,  outside the circuit before ordering / changing them ?
Normally you isolate the sections,  remove the mains capacitors for tests,  test the rectifier bridge forward and backwards and you test the continuity of the transformer primary sides and secondary sides, you may have an blown thermal fuse in it.
The x-former secondary ohms values seems good, i do hope you take measurements in AC before the rectifier bridge and DC after the rectifier bridge ??
To me your x-former main ac voltage should be between the gray and brown colored wires,  you see an capacitor between theses pins,  i think the green 117.7v value between yellow and brown is not okay, it may simply an induced voltage in the wiring ...  you have voltages taps to select the main ac voltages, you check continuity between all the primary wirings.
« Last Edit: September 26, 2018, 12:05:32 pm by coromonadalix »
Offline ArthurDent
« Reply #7 on: September 26, 2018, 01:45:58 pm »
When you say: “when i apply power when it's CONNECTED to the boards downstream IN the keyboard ... the dim bulb becomes a very very BRIGHT one and stays that way (so i try not to keep it on too long!)”. That indicates the transformer can’t be open. However, with a good transformer all the readings you put on the schematic don’t make any sense so there appears to be something wrong with your testing procedure.
The A.C. voltage from BE to BE should be the same as from YE to YE and perhaps about 10 to 12 VAC. The D.C. voltage from D5 to common should be the same as from D7 to common and perhaps 12 to 15 VDC. Double check your meter switch settings.
With no load connected are the measured outputs +/-15 and +/-8.5 as you have listed? I assume this bulb you speak of is in series with the A.C. power going to the unit. What wattage size is the bulb and how many watts does the unit draw? If the label on the unit says it draws 80 watts and you have a 40 watt incandescent bulb, the bulb may light with the supply connected to the load but the unit will not receive much or any power. Does the bulb also light with no load connected to the supply?
The primary wiring diagram to the transformer is incomplete and doesn’t make any sense as shown but if that wiring hasn’t been modified and the bulb lights with the load connected, I assume that wiring is o.k.. I would not recommend disconnecting any of the transformer leads except as a last resort, it could lead to more problems. You should recheck all your meter readings. If the output voltage readings are correct with no load, the problem is probably in the load and not the supply. The fuse that blew did its job by protecting the rest of the circuitry.
Offline kc7gr-15
    • Blue Feather Technologies
« Reply #8 on: September 26, 2018, 10:06:32 pm »
FWIW -- I would be suspicious of the bridge diode modules, D1/D2 and D3/D4. I've fixed other power supplies where the bridge module itself developed one or more shorted diodes, internally. I've also seen them fail open (though that usually comes with visible or odiferous signs -- translation: smoke and stench).
In any case: Unlike many switchers, linear supplies don't need a load to produce normal output. Power the supply without any load, then poke around with a multimeter to see if the regulators are working.
Happy tweaking.
Bruce Lane, ARS KC7GR
'Quando Omni Flunkus Moritati' (Red Green)
Offline jaunty
« Reply #9 on: September 26, 2018, 10:13:26 pm »
thanks - the diodes are definitely not shorted - at least from in circuit testing (which should be reliable for detecting a short) but I haven't removed them to test individually yet ...
Offline jaunty
« Reply #10 on: September 26, 2018, 10:16:59 pm »
perhaps THIS is the missing part and explains the weird behaviour - why it only lights up the bulb when connected -
 the primary side is open circuit unless the power supply is connected to the rest of the circuitry (though this is kind of dangerous for me - with a ps in unknown condition and 'unobatinium' parts downstream ...)
« Last Edit: September 26, 2018, 11:08:23 pm by jaunty »
Offline jaunty
« Reply #11 on: September 26, 2018, 10:19:10 pm »
although i measure 6.1 ohms across the primary winding i suppose i ought to test the transformer in isolation from the power supply ... it's just that it's such a bugger to disconnect it from the rest of the circuit ... so not an easy feat ...
note: I will answer individual question in detail shortly - thanks
« Last Edit: September 26, 2018, 10:23:00 pm by jaunty »
Offline Fryguy
« Reply #12 on: September 26, 2018, 10:28:32 pm »
Happy tweaking.
Don't forget to connect the sense lines to their respective outputs !   Load or no load .   And yes - happy tweaking  :-+
« Last Edit: September 26, 2018, 10:31:19 pm by Fryguy »
May the forces of evil get confused on their way to your home !
Offline ArthurDent
« Reply #13 on: September 26, 2018, 11:22:12 pm »
This is what the primary side actually looks like without the confusion caused by the connectors. With the switch closed there should be resistance between the two active prongs on the A.C. cord. If there is no resistance then the last paragraph may be the answer
I'd still like to know some of the answers to points I raised in post #7. I still think disconnecting transformer leads is a bad idea unless you know there is an actual problem with the transformer.
There is one possibility that might explain what you're seeing IF the bulb you reference is a neon indicator lamp and not a test incandescent bulb in series with the A.C. line, which is what I originally thought you meant. If the GY lead is open at the transformer there could be leakage through the R-C circuit across the switch and the neon might glow dimly with the switch open. Some transformers have a thermal fuse in the transformer to protect from overheating and if this transformer has one, it may have opened, disconnecting the GY wire. When the switch is closed that neon would glow brightly IF the GY wire is open at the transformer. There appears to be an unconnected 110VAC winding on the transformer and if you really know what you're doing you could disconnect the primary leads now used on the transformer and connect a  fused cord to those unused leads to test power the power supply with no load. These leads may have been there to wire in series with the other winding to operate the unit from 230VAC, I don't know. Don't try this unless you're pretty sure that the gray wire is open and you know what you're doing. I'm not responsible for burns or smoke damage. I would only try this for testing with no load connected to see if the rest of the power supply works.
« Last Edit: September 27, 2018, 12:07:59 am by ArthurDent »
Offline jaunty
« Reply #14 on: September 26, 2018, 11:34:35 pm »
Yes sorry Arthur i was in the middle of some work and i'm just getting around to 'processing' some of this - i'm grateful for the answers (and questions) so far ...
no - with no load connected (and what looks like a disconnected primary vis a vis the second diagram posted (so maybe that's my problem - it's a very weird setup compared to most such keyboards i've worked on) i only get millivolts ... maybe just spurious readings bleeding back through the circuitry???  my dim bulb tester bulb is a 60 watt bulb ...
so i guess my confusion is due to the fact (it looks??) that it cannot be tested outside of the keyboard - not without jumpering some of the connections anyway ... i was under the impression ONLY the sense lines needed jumpering but apparently it's not so ... (duh!)
PS - Zaphod told me to remove the transformer for testing ... i shouldn't trust him?
« Last Edit: September 26, 2018, 11:44:03 pm by jaunty »
Offline jaunty
« Reply #15 on: September 26, 2018, 11:42:16 pm »
yes - i have the pos. and neg. 15 volt sense lines connected (shorted to their respective feeds).  just before this I went through and did a 'full refurb' and put in new nichicon 105 degree capacitors (3300 uf instead of 2200 - all others same value) and new 4558s on the board ...
i think my problem with the primary side might be 'fixed' (see previous post to this) - due to a total oversight (second diagram) ... can you point me to a procedure to check the bridge rectifiers? i have only tested the diodes in circuit - nothing shorted that i can tell and seem to be acting as one would expect while in circuit and unpowered ...  i will also check the situation with the yellow primary etc ... could be an error somewhere.
Offline ArthurDent
« Reply #16 on: September 27, 2018, 12:14:56 am »
Sorry, I just thought of something else and edited my post #13. I also was enjoying an intergalactic gargle blaster so I might be a little messed up. :scared:
Offline jaunty
« Reply #17 on: September 27, 2018, 12:15:59 am »
THANK YOU SO MUCH ARTHUR for helping me see the problem in my 'measurement' .. stupid though it is not to have seen it ... hopefully i will get to the repair solution much more quickly now .. can't be understated the problems myopia can cause
Offline james_s
« Reply #18 on: September 27, 2018, 12:41:10 am »
If I understand your post right, it sounds to me like the problem may not be in the power supply at all, but in the keyboard.
Also I see you mention the problem occurred after you did some other work on it. Did the problem occur immediately or did it work for a period of time and then fail? If the problem happened immediately then the first thing I'd suspect is a mistake somewhere. Something plugged in the wrong place or backward, a solder bridge or the wrong part installed somewhere.
Offline ArthurDent
« Reply #19 on: September 27, 2018, 12:49:13 am »
With both + and - supplies it might be easy to put one of the replacement caps in backwards. Not that I've ever done that.  :palm:
Offline jaunty
« Reply #20 on: September 27, 2018, 03:04:45 am »
why would you think any caps were put in backwards ... no they were put in the same way ... i did that with a tant before but luckily i caught it !! helps to double check things :) i'm terrified of putting caps in backwards
Offline jaunty
« Reply #21 on: September 27, 2018, 03:09:40 am »
well in a way ... since i didn't realize part of the primary circuit was in the keyboard itself - so i had to jumper some things to get the primary to work ... silly me.
as for the 'work' - no the work started AFTER the fuse blowing started ... but now that i have the primary side figured out i'm lighting up the dim bulb indicator with the PS alone ... so there's definitely something going on there - MAYBE a diode pair ... i need to investigate further ... that's also the problem i guess - with doing refurb work before investigating a problem - it's possible to create new problems! i hope to god i haven't done that but i do think i've been very cautious
Offline jaunty
« Reply #22 on: September 27, 2018, 03:12:49 am »
SO - now that i have the primary wiring issue solved i have NEW RESULTS:
dim bulb LIT (finally) (means at least the transformer might be good)
YELLOW PAIR: 3.1V AC BLUE PAIR: 2.9V AC RED PAIR: 4.5V AC ORANGE PAIR: 8.6V AC
corresponding capacitors read: 3.1VDC 4.4V DC 7.8VDC and the last cap i couldn't read since it was inccessible and I didn't want to short anything with the meter probes in this case .. but after i disconnected the power i probed around the corresponding diodes and found what MAY be a short (reading close to zero under diode testing mode on my meter - I'll pull the offending diodes and check them properly ...
does anyone know where i can get a recplacement for a 10DC-4 and 10DC-4R diode bridge pair?? looks like this: https://www.jauce.com/auction/p573041848
« Last Edit: September 27, 2018, 03:19:03 am by jaunty »
Offline jaunty
« Reply #23 on: September 27, 2018, 05:45:23 am »
SO - i just connected grey/brown primaries directly to mains and get the following:
yes i did thanks - - new results: YELLOW: 2.2 BLUE : 2.9 RED: 4.5 ORANGE: 2.2 (all readings VAC) -that's across the secondary windings - relative to ground each is 27-30 VAC
capactors (VDC) : 3.1, 4.5, 7.9 ...
 this is with secondaries connected ...
« Last Edit: September 27, 2018, 06:08:59 am by jaunty »
Offline jaunty
« Reply #24 on: September 27, 2018, 05:46:07 am »
could it be a bad (partly shorted) transformer??
