I have restored several linear SL 1731SB PSU.
They are very very common, of cheap through hole construction 2 x 30 V -3A + 5V .
They are avilable under various names : Velleman PS23023, HY3003F-3, and maybe some other ones.
https://www.eevblog.com/forum/repair/tracking-problem-in-a-dual-bench-power-supply/msg529140/#msg529140The schematics is attached
Recently, I had also a single channel one (SL 1730SB), which I use as a benchmark here.
My problem is that there are spikes in the output that I cannot get rid of.
In this unit, I changed all electrolytic caps. I changed the LM324, the 2 741, the 7812, all the transistors
( 3 KSC1008 and 1 KSA708 )
But I have still these spikes.
Let me also say that these spikes appear whatever the method I use to measure the signal : without load, with a 22 Ohm load, and whatever is the output voltage.
In a surprising manner, in another unit, they do not appear.
https://www.eevblog.com/forum/chat/show-me-your-psu-noise/msg936429/#msg936429I will be very pleased if someone has a clue of where these spikes come from.
