My first post here, but i'm in a similar predicament with a Linn Kinos that I've been asked to take a peek at and am trying to decide the best next step to take. Any advice would be greatly appreciated.
I was given the unit to look at because "it wouldn't power up" and to see if there was anything i could do as the Linn repairs were prohibitively expensive.
I noticed some damaged caps on the PSU module (heat damaged) so started by replacing those. I then got some solid (+/- 17 and +/- 6 volt) outputs from the PSU.
The Kinos then starts to power up and i get a 'Loading Operating System' message on the display (which is very very dim). So, i'm making progress I think...
With it perpetually 'Loading OS' i then scoped around the boards looking at power rails. I found 3 that didn't appear to be in spec (i.e. had 3V ripple on a 5V rail). Suspecting the electrolytic caps again i replaced them and the rails snapped back into spec again. More progress i thought...
After a few cups of tea the Kinos suddenly sprung into life and worked, it worked repeatedly every power-up
. I went to try it out again the next day before boxing it back up and the damn thing didn't work again (stuck loading OS). It looks lke its trying to do some internal checks (internal status LED's flashing) then gives up.
As a last resort I borrowed MrsTea's hair dryer and warmed the boards up gently... The Kinos then sprang into life again.
It also still has a very dim and pixelated VFD display.
I'm thinking that some internal power rails are not in spec so the Kinos is failing some Built-In-Test checks.
I've seen thermal instability related to faulty IC's but warming them up usually made them fail not work!, hence me suspecting the caps...
On the boards there are about 65 surface mount electrolytic capacitors, mostly around voltage regulator IC's. My thought is to replace them all but this sounds quite drastic, what do you think?
I think the dim VFD is possibly another fault so i'll take a look at that once i can get the Kinos to reliably power up without the aid of a hairdryer!
