You should just leave it at I brought XYZ, and this is my failure analysis.
There are hundreds of PC power supply brands and 95% of them aren't worth buying when you consider a failure or a surge can take out your supply/board/ram/cpu etc.
This is not a problem that needs a solution it's been like this for 30 years or more? They make em cheap on purpose, noone cares unless you are a sucker and buy a pc with a dirt cheap power supply and get told later you brought trash.
Edit:
A realistic formula would be 20% of motherboard/cpu/ram cost. But if you are buying a decent GPU or a lot of storage you're getting a good power supply no matter what. Never spend $60 and run $2000 of gear off it, that is just asking for it. I also don't like buying mainland chinese products, Taiwan has much more experience in this area. Don't buy parts from companies that don't have websites unless you consider them disposable parts as it's probably some other rubbish brand relabeled anyway.
