Greetings folks. I have _two_ Mackie HUIs with PSUs that are not regulating on the +/- 15 VDC rails. They are based on LM317 and LM337. I have found and changed a few bad caps (changed all electrolytics regardless), refreshed diodes in bridge, checked all diodes, all resistors etc., replaced the LM317 and LM337 and tested with supplied transformer (providing ~37VAC, once rectified and split this gives ~24VDC per side). The PSU does not regulate, even when loaded with 220 Ohm 5W resistors, what goes in comes out the other side. Regulators were tested in simple breadboard circuit prior to install!
I am seeking hints. Also trying to understand the purpose of R15 and R16, 30 Ohm power resistors bridging each input and output. These were not in the breadboard test circuit.
Attaching a simplified schematic derived from the one in the service manual.
Thanks in advance for any advice!
