Several days ago, my grandmother smelled something unusual near the breaker panel in the garage. It was full of corrosion and things were falling apart. A week ago today, the electrician she hired replaced all the breakers and bus assemblies in all three panels. Today, just a week later, this is what it looks like. From the looks of it, one might assume nothing was replaced, however, the ones he removed are still sitting on the floor and she witnessed the new ones go in.
There are a few mysteries. This is an interior wall with no plumbing and everything in the attic directly above is perfectly dry. There is no cold draft coming from the conduit, the panel enclosure is not cold and the metal does not seem to be collecting condensation. There is a sticky black goo coming from essentially every one of the wiring jackets. The white/yellow corrosion tastes salty and our first assumption was that the garage floor heat is putting too much salty moisture (from vehicles) in the air, but the 50 year old steel square hanging on the wall right by the panels is not rusting, nor is anything else in the garage.
Anyone know what can cause this to happen in a week?
