I picked up this sub for $10, knowing it didn't work. Also knowing that it's a notoriously unreliable piece of equipment that, when working, sounds OK.
Upon closer inspection, the driver itself seems sound.. no rubbing. Amp powers on, meaning red indicator LED lights up, but no sound at all, other than a VERY loud sharp crack when turning off the power. Soooo... removed and disassembled the amp. Now.. questions...
Question #1 - Does anyone have a schematic for the amp in this powered subwoofer? I spoke with Polk today and they informed me they did not have anything available for that model.
#2. I'm assuming this jumper wire I found underneath the control board is not original. Can anyone confirm that this is a bad attempt at fixing something rather than factory?
Also noticed that, on the same board, jumper wire W19 is missing, although there are remnants of that wire existing in the eyelets...
... also notice, in that pic, lots of brown goo around the green caps and slight deformation, although they measured within tolerance of the correct capacitance. I don't have anything that'll measure ESR.
And... on the main amp board, the large main 10,000 mfd 50V caps have brown crap underneath them, although they, too, measure within tolerance on my multimeter's capacitance function. Does this mean they're shot? Brown stuff indicated by yellow arrows...
At this point, I realize that the usual advice is, "scrap the amp, put in a new subwoofer plate amp and call it good," but I'm approaching this project as an opportunity to learn more about the repair process.
Anyone have any experience working on this amp? I've found YouLube videos addressing the "heartbeat" constant noise issue, but nothing specifically for no output at all except for a crack on power-off.
The phase toggle switch was completely frozen and inop, but I've found a replacement for that.
Any ideas/help would be, of course, appreciated.
