Electronics => Repair => Topic started by: Ground_Loop on April 19, 2023, 12:25:30 pm
I was having connection problems between my mouse and this receiver. The connection was intermittent. A look under the micro scope revealed the problem. A 0201 C13 in the antenna matching network has run off. Since this is what I assume to be a tuned matching circuit, any ole coupling cap will probably not be optimal. I have another receiver, but really don't want to snap the top off to see what the cap value might be. The dongle operates at 2.4GHz feeding a trace antenna. Any thoughts on what a range of values might be?
What's the part number on the transceiver? In the past, Logitech used TI's CC25xx parts.
It's NRFD24LU1P. I added another pic. Also found a data sheet and it looks like I'll need a 1.2pF cap in 0201.
I scraped some solder mask off the trace and scabbed in an 0603. Works perfectly.
