Author Topic: Logitech z-506 amp/speakers  (Read 2674 times)
Offline awyeh1234Topic starter
« on: November 07, 2014, 08:48:21 pm »
Hello i have this set of logitech speakers and one day out of the blue they just stopped working.  the power light turns on but if you put a signal into it nothing happens. any suggestions?
Offline poot36
Re: Logitech z-506 amp/speakers
« Reply #1 on: November 10, 2014, 07:29:28 am »
Have you taken them apart and measured the voltages on the amp chips pins and compared them to the datasheets values?
Offline Whales
    • Halestrom
« Reply #2 on: November 10, 2014, 08:25:21 am »
Although the light is coming on, the power supply might be faulty (feeding out-of-spec power).  If you have a power supply/plug pack rated to the same output voltage, try that on it.
