Hello,
I have the same problem damaged the components on the power supply, I do not know if there is a sense to play in the repair, I would prefer to apply your solution with an alternative power supply. You write that the whole works well, could I ask for more photos, information, so that I could do the repair also in my set? It was the least useful to photograph the whole from the top and bottom so that I would know how to combine everything.
In poland I can not find a transformer with parameters, can an alternative be a power supply with the same parameters?
Power Supply:
http://sklep.cncprofi.com/zasilacz-impulsowy-36v-230v-350w-10a-cnc.htmlI also have a question about the regulator, he is also not in the stores in Poland, I would have to draw from China or is it right? I am asking because there is no IC designation?
Voltage regulator:
https://pl.aliexpress.com/item/10pcs-AMS1117-3-3V-AMS1117-1117-3-3V-1A-Voltage-Regulator-LDO-SOT-223/32830638042.html?spm=a2g17.search0104. 3.9.7128f4388OVRq5 & ws_ab_test = searchweb0_0, searchweb201602_2_10065_10068_5726815_10843_10059_10884_10887_312_10696_100031_10084_10083_5726915_10103_10618_10304_10307_10820_10821_10302_528, searchweb201603_60, ppcSwitch_5 & algo_expid = d3f71029-56df-47c4-a732-564358fa6716-1 & algo_pvid = d3f71029-56df-47c4-a732-564358fa6716 & transAbTest = ae803_1 & priceBeautifyAB = 0
