I've had exactly the same here.. My z906 worked for 20min, then wouldn't turn on anmore unless I gave it a 24-48h break. Then again: 10-20min. I tried everything I could find on the net (except replacing all caps) but nothing helped. I only saw the LED 5 and AUX lit up. I checked serial comm between console and main board: nothing on scope, no reaction when I sent commands from PC instead of console (search for z906 on github).
When I sent a pic to a friend, he told me he'd remove the black snot. He has seen it becoming conductive over time.
So I measured it: over the amp section it was infinite, over some parts of the audio input 1-2M
and over the logic section I measured 200k
In a 3h session, I removed all the black stuff. Mostly it was brittle and in some parts sticky (dangerous for SMD). I gave extra care with a needle pin between the legs of U22. Then I put it all together and tadaaaah!! It works fine for hours now
Be cautios though: It's easy to lift/crack an smd component or cut a trace. I used a swiss army knife (scalpel will work too), held it almost parallel to the PCB and when it got hold of the black stuff, I lifted upwards. Sometimes you'll have to try different angles. But NEVER cut downwards (except alongside a capacitor where you're sure nothing is below). Only upwards motions! And take breaks.. the longer it takes, the sloppier and impatient you get.
Unfortunately I still managed to break a transistor:
Q8 (to the right of the "Sub out" connector).
If anyone could tell me what part it is, I'd be most thankful. Beacuase with that DTS/DD5.1 mode doesn't work and I only get Surround (the "decode" light never lights up). It is connected to Q6/Q7 over R290 and R292. Q6 and Q7 are have written "W1P 17" on them (so likely pnp transistors?). Their base's are connected via the resistors to Q8.
