Length normally used because the wider ones do not fit the limited area on the board. If you have wider low ESR 105C capacitors which will still fit there no problem to use them, generally the longer ones are used for tighter packing, but the manufacturer could be using them simply because they have them in stock and the board layout can fit wider ones, as often you see the screen printed layout has a few different diameters printed as concentric circles, the actual capacitor fitted depends what is on the machine that day, or what they have in stock in that value and voltage. Otherwise the ESR is the same, the voltage the same or slightly higher, and capacitance the same or slightly higher, and they fit the pitch of the leads no problem to use other diameter cans.
