Author Topic: Looking for a capacitor  (Read 926 times)
Offline MagnumTopic starter
« on: March 17, 2024, 07:21:16 pm »
Hello,
I am looking for a capacitor, I think the english word is safety or suppression capacitor.
It is from a heater controller between mains. It blew up, I removed it and now the controller works again.
Unfortunately I can't find it online, can someone tell me what I could use instead? It seems to be 5nF Y1?
Many thanks!
Offline fzabkar
Re: Looking for a capacitor
« Reply #1 on: March 17, 2024, 07:42:55 pm »
« Last Edit: March 17, 2024, 08:08:21 pm by fzabkar »
Offline TimFox
« Reply #2 on: March 17, 2024, 07:43:39 pm »
« Reply #3 on: March 17, 2024, 07:52:41 pm »
Thank you for your help.
In Germany I found this one, does it matter if it is Y1 or Y2?
https://www.pollin.de/p/entstoerkondensator-4-7-nf-250-v-rm-10-y2-200693
« Reply #4 on: March 17, 2024, 07:53:39 pm »
Ok, I found the explanation for Y1 and Y2. IMHO Y2 should also be fine...
Offline Gyro
« Reply #5 on: March 17, 2024, 08:47:24 pm »
That should never happen with a Y cap. It is there to provide interference suppression but safe isolation between primary (mains) and secondary sides, or primary and ground. Y1 capacitors have a test voltage of 8kV and Y2, 5kV. What happened? Nearby lightning strike?
« Last Edit: March 17, 2024, 08:49:03 pm by Gyro »
Best Regards, Chris
Offline fzabkar
« Reply #6 on: March 17, 2024, 08:54:21 pm »
If the capacitor is connected from line to line, then it's an X class capacitor, not Y class.
That said, your chosen replacement appears to be X1/Y2 rated.
« Last Edit: March 17, 2024, 08:55:59 pm by fzabkar »
Online Zero999
  • 0999
« Reply #7 on: March 17, 2024, 09:12:54 pm »
Does the rest of the circuit work? Assuming it's not a fake Y capacitor, then I would expect other parts to be badly damaged it replacing it will not fix it.
« Reply #8 on: March 20, 2024, 06:24:03 pm »
Sorry for the late reply.
The rest of the circuit works after I removed the capacitor. I don't know what happened as no-one was at home when it blew.
The one I ordered is a Y2, I have to recheck if it connects between mains or to ground.
Thank you for all your help and information!
Offline gamalot
  • Correct my English
    • Youtube
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
The following users thanked this post: Magnum
« Reply #10 on: March 21, 2024, 10:09:45 am »
Thank you!
