Author Topic: Looking for a replacement audio jack  (Read 5672 times)
Offline in06khattabTopic starter
« on: December 17, 2016, 05:23:53 pm »
I am trying to repair a PC audio jack, however I am not able to find a replacement which is the same as the original.
This is the PC board that I am reparing. I am reparing the headphone port. On the outside it says Clsj.
Can anyone help find a replacement part?
Here is the pinout of the part, 3 and 4 short together when plugged in.
« Last Edit: December 17, 2016, 07:19:45 pm by in06khattab »
Offline Andy Watson
Re: Looking for a replacement audio jack
« Reply #1 on: December 17, 2016, 06:04:20 pm »
« Reply #2 on: December 17, 2016, 06:10:48 pm »
I have tried that pinout, it does't work. The PC thinks there is a mic plugged in, when nothing is plugged in and everything unplugged when a headphone is plugged into the jack.
I can't seem to find a jack with that pinout configuration
« Reply #3 on: December 17, 2016, 07:20:10 pm »
Just to clarify, 3 and 4 short together when plugged in (on the picture above)
Offline helius
« Reply #4 on: December 17, 2016, 08:34:17 pm »
The usual nomenclature and operation is that certain pins are normaled to others. When the plug is inserted, these normal connections are broken. It is much less common for such connections to be made by insertion; what may be happening is that the connection is via the plug barrel, so if an all-plastic plug was used they would not be connected. They are sometimes designed this way though.
In this diagram, jack "D" has only normaled connections, which are broken when the plug is inserted. Jack "C" has pins that detect insertion but are not connected to the plug itself: the triangles don't conduct.
« Reply #6 on: December 17, 2016, 10:25:16 pm »
Thanks a lot for your help, I have tried http://uk.farnell.com/switchcraft/35rapc4bhn2/connector-rca-jack-3-5mm-tht-5way/dp/1608405 and https://www.sparkfun.com/products/8032, but they both didn't work. It seems that the pinout of the Cliff FC68133 is the same as the first link.
Offline Fisher77
« Reply #7 on: December 20, 2016, 01:30:40 am »
Here is all of the pc audio jacks: http://www.iccfl.com/index.php?cPath=139_140
Offline sergeyzuzic
  • Country: ru
« Reply #8 on: January 26, 2018, 08:30:48 pm »
I'm looking for the same connector.
2 central short together when headphones are connected.
Zalman Z9 Panel, same brand Clsj
PJ-396 ?
« Last Edit: January 26, 2018, 09:54:44 pm by sergeyzuzic »
Offline quito79
  • Country: pt
« Reply #9 on: May 29, 2018, 07:50:31 pm »
I don't know if you already found what you need. But, in case you don't, here it is:
35RAPC4BHN2 -  Phone Audio Connector, 5 Contacts, Jack, 3.5 mm, PCB Mount, Silver Plated Contacts, Plastic Body
brand: SwitchCraft
I bought them from Farnell around 1 dolar a piece (+/-)
Regards
Offline bdani96
  • Country: hu
  • Gamer
« Reply #10 on: February 16, 2019, 12:36:08 pm »
I have the same problem with the same brand's other jack socket.
It has an isolation plastic between the jack plug and the "switch" which is just broke off and then the plug short the 3 connections and the socket is unusable.
I find an another socket that look exactly the same (PJ-358), but the layout is different and it's not working with my computer.
The computer case is Thermaltake Core V21
Pictures and schematic: https://imgur.com/a/iHKLgsE
« Last Edit: February 16, 2019, 01:47:30 pm by bdani96 »
Offline bdani96
  • Country: hu
  • Gamer
« Reply #11 on: April 11, 2019, 09:07:14 am »
Anyone?
Offline LateLesley
  • Country: scotland
« Reply #12 on: April 12, 2019, 01:48:52 am »
The closest I can find is the PJ 358, but I can't find a version with a switch inside.
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20190411174718&SearchText=PJ+358
Offline bdani96
  • Country: hu
  • Gamer
« Reply #13 on: April 12, 2019, 06:43:24 am »
Yes, thats my biggest problem, without the switch it doesn't work :c
Offline LateLesley
  • Country: scotland
« Last Edit: April 12, 2019, 10:53:28 am by LateLesley »
Offline bdani96
  • Country: hu
  • Gamer
« Reply #15 on: April 12, 2019, 02:59:38 pm »
This is looks like what i want
http://www.zirui.net/3-5mm-phone-jack/phone-jack-pj-31580.htm
Edit:
But i can't find anything on ebay or ali.
« Last Edit: April 12, 2019, 03:01:53 pm by bdani96 »
Offline Ordinaryman1971
« Reply #16 on: April 12, 2019, 06:13:20 pm »
It looks just like a jack behind the front panel of the older Dell Dimension Desktops. Maybe that's the way to go, salvage it from some older computer equipment.
Wanted to ask, where was it installed? What was the application?
Offline bdani96
  • Country: hu
  • Gamer
« Reply #17 on: April 12, 2019, 06:51:25 pm »
Its my cumputer case's front audio io, Thermaltake Core V21
Edit:
« Last Edit: April 12, 2019, 07:02:52 pm by bdani96 »
Offline bdani96
  • Country: hu
  • Gamer
« Reply #18 on: May 24, 2019, 03:13:02 pm »
So after many buy, i finally found the replacement one for theese ... so, there is, they look like this:
Offline rockeinstone
  • Country: id
« Reply #19 on: March 24, 2021, 11:40:38 pm »
hi i am confused which one you found that is fit with your thermaltake case? pj358? but u said pj358 did not work with yours ? loll.. i signed up on this forum just to ask this??
because i also have the same brand case Thermaltake but just different model versa h18. my socket was broken one of it.
so if u can help me to fix it, it would be a big favor for me?? thanksss...
Offline bdani96
  • Country: hu
  • Gamer
« Reply #20 on: March 26, 2021, 01:40:21 am »
So, like the socket's name is PJ358(or PJ-358, etc.), but there are different variants of this socket, like 4 variations if i remember right.
The good ones have an isolation between the "switch" and the jack plug, the bad ones not.
The good ones looks like the green and the pink ones that i have(from the bottom), like on my pictures, the bad ones looks almost similar like the original black, but there are no isolation between the switch and the jack plug's ground.
I have bought them from a chinese seller, from aliexpress, like this was my 6th buy for try.
I bought from this seller the good ones: https://www.aliexpress.com/item/32910679137.html?spm=a2g0s.9042311.0.0.1f3f4c4dXPyaPK
This seller is selling identical like on the pictures, others not really, like i bought from a seller who have the same pictures but selling the bad ones.
« Last Edit: March 26, 2021, 01:42:32 am by bdani96 »
