Author Topic: [SOLVED] Looking for a replacement for obsolete NPN transistor  (Read 1142 times)
Offline ThermoelectricTopic starter
« on: September 30, 2019, 09:48:53 am »
Hi all,
Replaced a board in an airconditioner today, turns out it was getting damaged due to a faulty motor and as a result I killed the new board as well. As far as I can tell, the only part that is damaged is a NPN transistor, "2SC4487" (seized motor, high current burning out transistor). This seems to be an obsolete part and is not available on RS Components or Element 14.
Just wondering if anyone can recommend a replacement? I'd try myself but it seems a little specialised (also in an odd package) so I assume it's not as simple as swapping in a bog standard NPN with the same current and voltage ratings. Datasheet I've found for it is here: https://au.mouser.com/datasheet/2/308/EN3093-D-310398.pdf
Cheers for any help!
« Last Edit: October 03, 2019, 06:11:30 am by Thermoelectric »
Offline andy3055
Offline andy3055
Re: Looking for a replacement for obsolete NPN transistor
« Reply #2 on: October 01, 2019, 06:07:56 pm »
OOPS! No stock there either. Sorry about that.
Offline andy3055
« Reply #3 on: October 01, 2019, 06:43:44 pm »
https://www.mouser.com/ProductDetail/ON-Semiconductor/2SC4487S-AN?qs=%2Fha2pyFadug6CxAhJFA9Q6Zapg7M7mTnkp8tJ4fX2tnhIEiKyQJUdg%3D%3D
Click on the "Compare with current part" button on the right bottom.Looks like 2SC5706-H can be used as a replacement and Mouser has a stock of 95 pieces.
Good luck
https://www.mouser.com/ProductDetail/?qs=8nbDJddAfDVBNGZ994JVLA%3D%3D
The following users thanked this post: Thermoelectric
Offline andy3055
« Reply #4 on: October 01, 2019, 06:48:01 pm »
Here is another link: https://alltransistors.com/crsearch.php?mat=Si&struct=NPN&pc=1&ucb=60&ic=3&tj=150&hfe=30&caps=X73
It shows 2SC4482 as a possible replacement-at the bottom left.
Re: [SOLVED] Looking for a replacement for obsolete NPN transistor
« Reply #5 on: October 03, 2019, 06:12:29 am »
You beauty. Gonna give the 2SC5706 a shot.
Cheers mate!
