I'm going through an HP 334a distortion analyzer and discovered a p-channel JFET on the rejection amp board was replaced with a component of questionable compatibility after failing to adjust bias at A3TP2 within a certain range. The service manual for the analyzer specs Q4 as a TI SFB 2696 (1250μs, 4ma), and the component in its place is a Siliconix device numbered "5-006 7340". I wasn't able to find data on either part.
Does anyone have any info on these JFETs? What might be a good substitute for the original part?
I found a TI semiconductor catalog from 1966 and was't able to correlate any of the FETs listed with the part no. 2696. There was a 2N2696, a general purpose transistor, but Q4 is very much a JFET.
Thanks for any help
edit: I did some more sleuthing and found the siliconix part is OEM.
