The part number you give, link to a display processor in the Hp Agilent Keysight 34401a multimeter
You can buy an replacement processor at Digikey, Mouser etc ... but you will need the firmware dump of your power supply ic's as you know
And keysight will not sell you this one with the version 11 firmware, you'll need to send your meter ...
You have this repertory with an service manual and a zipped file of u14
http://www.ko4bb.com/getsimple/index.php?id=manuals&dir=HP_Agilent/Agilent_E3631ABut in your psu you have at least 2 of theses cpu, the last digits of the cpu model is important
Electronic parts for you power supply may or will start with 3631-xxxx part designatorI think you should correct your first thread title, its misleading ?? you need the E3631A cpu FW
You can create a free acount at Keysight and search parts for your 3631 psu ...Just did a search with my account, nope i dont see it available.
Oh sorry, you're right, they push a 34401a meter part number for U7 U10 ?? you've made an error in your chip numbering ..
SV manual
U7 34401-88804 IC-8-BIT MCU W/4K EPROM;12MHZ N87C51
U10 34401-88805 IC-8-BIT MCU W/8K EPROM N87C51FA
As i wrote, This chip is very common, unless it have a programmation ... aaaand you will need a fw dump
other link here for this psu
https://www.eevblog.com/forum/repair/e3631a-firmware-version-1-6/some service notes and other discutions
https://groups.io/g/HP-Agilent-Keysight-equipment/topic/32835924https://groups.io/g/HP-Agilent-Keysight-equipment/topic/24812732?p=,,,20,0,0,0::,,,0,0,0,24812732and a service note attached to this thread
