I'm currently trying to repair an ECM which uses some Motorola TY94084FB drivers. The one driving the injectors still kind of works but seems too weak to drive them.
I looked for the datasheet to see what the output current specs are and if there is stuff like current limiting, etc... to confirm this IC is the source of the problem 100 % sure, but it was impossible to find it. I also contacted NXP over their chat and they told me they don't have this part number in their database.
It's a 20 pins SOP with thermal pad accross the long side and has 4 outputs, with pins 2, 9, 12 and 19 being the drains/collectors.
I would be forever thankful if someone has any kind of information on that IC (even just the pinout would be a start...) or at least a similar IC.
