Author Topic: looking for modern equivillent for this axial condenser  (Read 1087 times)
Offline clubconsolesTopic starter
« on: October 20, 2018, 03:02:41 pm »
it is from a 1939 electronic dice game. It should be shunting a solenoid that pays out coins.
I have tested the solenoid and its fine and game has been rewired so no shorts as was the case with the old cloth covered wires!
Offline DaJMasta
    • medpants.com
Re: looking for modern equivillent for this axial condenser
« Reply #1 on: October 20, 2018, 03:10:28 pm »
It's hard to see from the picture, but a 5 MFD condenser is the same in modern description as a 5 Microfarad (uF) capacitor.  I can't tell if under that in the image is a 25V rating, but you just need a similarly rated modern capacitor.  Given the use case, probably any electrolytic should do a reasonable job, and going with a more standard value like 4.7uF should be fine as well.
« Reply #2 on: October 20, 2018, 03:22:40 pm »
many thanks for your reply.
thats the best pic i could get.
it reads
MT400 W. V.25 and there is 6-8 v and 24V DC coming from power pack so i will try your recommendation, thank you!
Offline james_s
« Reply #3 on: October 20, 2018, 10:27:00 pm »
I would suggest a 4.7uF film capacitor with a rating of at least 25VAC.
Something like this ought to work.
https://www.digikey.com/product-detail/en/illinois-capacitor/475MMR100K/1572-1229-ND/5412701
