Author Topic: looking for Phillips PLHC-T801A power supply schematic ?  (Read 2548 times)
Offline kripton2035Topic starter
« on: August 21, 2018, 04:48:26 pm »
if anyone ?
this would be very much appreciated.
it is for a 47" lcd tv.
thanks.
Online coromonadalix
Re: looking for Phillips PLHC-T801A power supply schematic ?
« Reply #1 on: August 21, 2018, 08:26:13 pm »
Search the part number on the board, it may tell you other tv models / sizes and do an google search ...
« Reply #2 on: August 21, 2018, 09:59:05 pm »
PLHC-T801A is the part number ?!?!?
google gives you people searching for it ;)
also people that seems to have the schematic, but only give clues to fix it
Offline shakalnokturn
« Reply #3 on: August 22, 2018, 11:22:04 am »
Not the exact PSU as the schematic given appears to be for up to 42" models:
http://www.go-gddq.com/upload/2009_06/LC8-2A-LA.pdf
Possibly close enough to at least help understand.
From personal experience with these psu's and from a first glance at the schematic beware of, (referring to schematic in link):
(bulging secondary capacitors of course...)
Bad solders on transformers
IC901 (ICE3AS02 standby power PWM)
C613,C625,C626 on main power
C310,C311,C315 on backlight power
« Reply #4 on: August 22, 2018, 04:10:35 pm »
thanks but this is not the right schematic.
the broken circuit is a fairchild FSQ510, there is none in this manual.
I replaced it (and a fried resistor)  but the power is still ticking (one relay is ticking in fact)
« Reply #5 on: August 22, 2018, 08:26:29 pm »
the tick maybe a synonym of an short circuit still present, the supply tries to start and shutdown because of the short ???
