IDK much about SMD labels, maybe a 7kohm ? Or some factory code I guess.
What was it from, do you know what the circuits around it are ? From that it might not be hard to guess a range, and then just try some resistors or potentiometer. But yeah what material would it be, and what should temperature coeff. be, IDK but if you're lucky, it's just some typical off-the-shelf PTC.
So yeah I'd want to know about the local circuit it's in.
