Author Topic: looking for replacement ICR12300 Battery for Livescribe  (Read 4287 times)
Offline CircuitousTopic starter
    • Corgi-Tronics
« on: May 30, 2015, 12:58:35 am »
I'm hoping to replace the Li-ion battery in my Livescribe Wifi pen, and I need to find one that will fit and work with the charging/protection circuit.
I am not an expert on LI batteries, and I hope someone will recognize this one.
  • Markings:  Great Power ICR12300 350 mAh 3.7V
  • Dimensions:  11.70mm x 27.6mm  (dia x len)
  • It also has long thin solder tabs.
I haven't welded tabs onto batteries, and was hoping to just find a direct replacement.
In the attached photo you can just see the charging/protection circuit on the end of the battery.  This is separate from the battery.
Any suggestions for alternative batteries or suppliers would be great!
Thank you.
Offline Johndi
Re: looking for replacement ICR12300 Battery for Livescribe
« Reply #1 on: May 31, 2015, 04:04:49 am »
Looks like the only thing remotely close is available at aliexpress: http://www.aliexpress.com/store/product/6pcs-lot-ANYSUN-icr12300-3-7V-350mAh-12300-li-ion-rechargeable-battery-cell-for-Livescribe-WiFI/1453301_32313341408.html
Have you tried contacting the sales department for Great Power?  I've found in the past, that sometimes contacting their sales department they will get you in contact with a distributor who is willing to sell one-off.
    • Corgi-Tronics
« Reply #2 on: June 01, 2015, 12:55:33 pm »
I haven't tried contacting Great Power,  but I might do that.
I did find a new battery on ebay with solder tabs that should arrive in 10 days or so.
Thanks for the suggestions.   If the eBay one doesn't work out, I'll contact great power.
« Last Edit: June 01, 2015, 12:57:29 pm by Circuitous »
