Author Topic: Seek Thermal Compact Pro USB Pin Out?  (Read 423 times)
Offline w0nk1Topic starter
« on: February 24, 2023, 02:56:33 pm »
Hi guys,
My Seek Thermal Compact Pro (Micro USB) went bad and I was tinkering around and tried to wire an external Micro USB male connector. Unfortunately, the ribbon cable was torn and I am not sure if I remapped the pins on the board correctly. I have attached a picture from the PCP of the camera with the ribbon cable connector removed. I have labeled the pins which I assume are the correct mappings. Does anyone know the pinout and can help me with the wiring?
Thanks so much! It would be a shame if the camera did not work just because of the wrong connections.
Cheers
Markus
« Last Edit: February 24, 2023, 03:00:46 pm by w0nk1 »
