Author Topic: Samsung SM-G955U cellphone over voltage repair help  (Read 756 times)
Offline poot36Topic starter
« on: November 06, 2021, 04:34:15 am »
I can find the schematics for the SM-G995F and for the SM-G950F but not for the SM-G955U which has a different board layout around the data and power connector on the main board.  I am trying to repair an over voltage that was sent into the phone through the charging jack by a defective charger (it got around 36V in the USB C port).  I have already replaced the IC labeled U804 in the SM-G995F schematic and now I have some voltages on the main PCB around the power management IC but it will not charge the battery or turn on.  The IC mentioned in the SM-G995F schematic is KTS1678EUQ-TR and the exact part I got from Mouser was this KTS1678BEUQ-TR.  Not sure if this is the correct part or not as I do not have the exact schematic to match my phone.  Is there some things/voltages I can check to see if another part needs replacing?
« Last Edit: November 07, 2021, 08:06:30 pm by poot36 »
Offline fzabkar
Re: Samsung SM-G955U cellphone over voltage repair help
« Reply #1 on: November 07, 2021, 08:12:36 pm »
They're only product briefs, but it would appear that the "B" version may just be a newer part with better specs.
https://www.mouser.com/datasheet/2/936/KTS1678-03m_Datasheet_Brief-1489359.pdf
https://www.kinet-ic.com/uploads/KTS1678B-04d_Datasheet_Brief.pdf
« Reply #2 on: November 08, 2021, 03:08:34 am »
I am just not sure that the part is even correct as the iFixit disassembly(Link: https://www.ifixit.com/Teardown/Samsung+Galaxy+S8++Teardown/87086) indicates that it may be this part: FPF3688UCX which I can not find at any major online parts sources.  Not sure what the differences may be.
Offline fzabkar
« Reply #3 on: November 08, 2021, 06:37:20 pm »
They could be compatible parts. Manufacturers often use second sources.
