I assume the colors changed due to the heat.
But, if that is indeed white, white, brown, that would mean 990 ohms. I measured both resistors, to 247 ohms and 461 ohms respectively.
Both should be the same, as the board is otherwise mirrored (I think for + and - voltage).
I have been thinking of drawing up a schematic for it, but that would be a lot of work. Both the PCB itself (comparing the trace on the underside with the components on the top side), and all cables leading to the transformer, power transistors, etc.. But I might still do that, eventually.
