Author Topic: [solved]schematic of "Invask Invasion SG15R" or "Epiphone Studio 15R" guitar amp  (Read 1561 times)
Offline GreybeardTopic starter
This is the guitar amp:
This Epiphone Studio 15R front layout looks very close, just mic input and level pot is missing, may be same PCB (?) :
I searched both in google but couldn't find schematics.
The SG15R contains a 2-spring reverb tank and a handful of JRC4558 OP amps.
« Last Edit: January 24, 2024, 08:15:16 am by Greybeard »
Does anyone know which guitar or amp forum I could ask for?
Offline donlisms
Doesn't anyone reverse-engineer anymore?  Goodness gracious - how did anyone ever fix anything before google?  :)  I will say this - when you invest the effort to draw a schematic, you end up with a pretty solid understanding of how the thing works!
Curious...  Why do you need the schematic?  Is broken?
No question I could reverse engineer the amp, if I invest about one workday. But why should I re-invent the wheel, anyone has done before in the best case?
It's not broken. The amp just sounds not as bad as I expected for such a cheap practice amp. In fact it sounds quite decent...
So I wanted to know what's inside the blackbox.
« Last Edit: January 10, 2024, 11:14:50 am by Greybeard »
Offline nanodocl
Try to contact the manufacturer directly, sometimes they share!
I asked manufacturer first but got no reply.
Sorry forgot to mention...
PS: Yesterday I received the Epiphone Studio 15R schematics from Gibson Customer Service.
After checking I can confirm the PCB is identical to the wanted Invask Invasion SG15R as I supposed, the Gibson/Epiphone is just missing one JRC4558 double OP amp and MIC-Level pot and input jack for MIC.
« Last Edit: January 24, 2024, 08:13:05 am by Greybeard »
Someone asked me for the schematics:
