Author Topic: Looking for the input connectors for Agilent 34420A  (Read 9107 times)
Offline nadonaTopic starter
« on: October 08, 2014, 09:55:14 pm »
I am looking for the input connectors for Agilent 34420A. I'd like to make a few for different ends and lengths.
Just something that fits to the terminal.
Thank you in advance.
« Last Edit: October 09, 2014, 02:45:02 am by nadona »
Ha-ha-ha. That's good, too!
Online macboy
Re: Looking for the input connectors for Agilent 34420A
« Reply #1 on: October 09, 2014, 01:07:41 pm »
Agilent/Keysight sells them directly. Part number 34104A, USD$125 each. They are likely proprietary, so you won't have any other choice.
The instrument should include one one shorting block, and one cable with Kelvin connections (for 4-wire resistance measurements). This is all low-thermal stuff with pure copper used throughout.
« Reply #2 on: October 10, 2014, 05:05:34 am »
Thank you.
Offline HighVoltage
Offline plesa
« Reply #4 on: December 06, 2015, 03:24:31 pm »
I just make investigation and input connector used on Agilent 34420A and maybe Keithley 2182 seems to be LEMO V series  connectors.
Replacement is FVN (cable or short) and EVP (meter) connectors.
http://www.lemo.com/catalog/ROW/UK_English/V_series_en.pdf
FVN-XX-304-CLAC-xx-Z
XX is probably 2V and xx depends on diameter of your cable.
If someone has original cable please measure diameter of nut.
Offline ManateeMafia
« Reply #5 on: December 07, 2015, 04:52:44 am »
I can confirm the shorting plug for a 34420A works perfectly with a 2182.
« Reply #6 on: December 07, 2015, 04:58:30 am »
If you are looking for Dimension A, I can measure it when I get home in about 3hrs.
« Reply #7 on: December 07, 2015, 08:52:24 am »
I measure ~15mm
The Lemo part number on the plug is FVN.1S
Offline engiadina
« Reply #8 on: December 07, 2015, 03:50:40 pm »
Well not quite ...
Actually it is
FVN.1S.304.CLYC37Z
Then you get even the raw copper contacts ...
Offline plesa
« Reply #9 on: December 07, 2015, 04:18:08 pm »
Well not quite ...
Actually it is
FVN.1S.304.CLYC37Z
That's a good point, that Lemo is not using  pure copper contact and they are using beryllium bronze, bronze and brass.
Info in official catalog (page 178)
http://www.lemo.com/catalog/ROW/UK_English/unipole_multipole.pdf
According to number it looks like really custom made connector for HP and not official in Lemo catalog ( V series housing, S series insert and contacts made from almost pure copper) So it will be probably better to buy replacement from Keysight.
Offline alanambrose
« Reply #10 on: March 11, 2016, 10:39:12 am »
>>> Actually it is FVN.1S.304.CLYC37Z
Can I check - is this the part # taken off a kosher set of Keysight/Keithley test leads?
TIA, Alan
“A foolish consistency is the hobgoblin of little minds"
Offline plesa
« Reply #11 on: March 12, 2016, 05:18:03 pm »
The PN does not contain information about copper contacts.Must be specfied separatelly.
https://www.eevblog.com/forum/repair/hpagilentkeysight-34420a-nanovoltmicro-ohm-meter-repair/
cable FVN.1S.304.CLYC37Z price 50 EUR
meter input connector is EVP.1S.304.CLY price 40EUR
both with copper contacts not gold plated.
Offline alanambrose
« Reply #12 on: March 14, 2016, 03:47:41 pm »
Many thanks plesa, btw where did you find it for 50 EUR - I'm getting £76 i.e. ~100 EUR. Keysight gave me these UK distributors:
Aspen Electronics Ltd (Premium Partner)
Amplicon Liveline Ltd
Microlease Plc
and Microlease for instance is quoting the £76/EUR 100 price?
TIA, Alan
