Author Topic: Low Frequency Continuity Beep for Fluke 8060A  (Read 475 times)
Offline Dave WiseTopic starter
« on: April 24, 2024, 10:24:43 pm »
I love my 8060A handheld DMM's instant continuity beep, except I can't hear it.  It's approximately 2700Hz but I have a hearing loss that notches it out.  I modified my 8060A to output a lower frequency that I can hear.
The mod is a tiny daughterboard that mounts on the main board in place of Q6, a 2N3904 that drives piezo sounder LS1.  We need one flying wire to pick up +5.2V Vdd to power the microcontroller.
Re: Low Frequency Continuity Beep for Fluke 8060A
« Reply #1 on: April 25, 2024, 07:22:27 pm »
I just noticed that attach failed and only the pictures got uploaded.  Here comes schematic, PCB layout, program, and assembly instructions.
I figured out a trick for extending the frequency range on small PIC microcontrollers whose Numerically Controlled Oscillator has an undersize (16 bits) Increment register.  It's in the program comments but I didn't test it as I'd already cut off the programming header.  Affected parts are PIC10F320/2, 12F1501, 16F1503/7/8/9, 16F1713/6/7/8/9.
« Last Edit: April 25, 2024, 07:28:46 pm by Dave Wise »
