Hi!
I doubt it would be an KA7553 – that's an Asian device and HP tended to limit themselves to Western designed/sourced pwm/controller devices, apart from that, Pin 6 on the KA7553 ts the Vcc pin and that certainly won't work if the PCB has no connection to it!
There's a pretty good chance that your 8 pin driver IC will be an Internional Rectifier IR2101 – you mentioned two BUZ332s, almost certainly you'll find the drain (middle leg) of one will go direct to the +H.T. line from the mains bridge rec., then the gate (left-hand lead) of the 'top' BUZ332 will lead back to pin 7 of the i.c., whilst the source (right-hand lead) of the 'top' BUZ332 goes to a series cap of about 2.2 uF to 4.7 uF, then the first primary pin of the main power transformer, then the second pin of the primary will lead back to the drain (middle lead) of the 'bottom' BUZ332, with the gate (left-hand lead) of the bottom BUZ332 going to pin 5 of the driver IC, with the source (right–hand lead) of the 'bottom' BUZ332 back to –H.T. from the mains bridge rectifier.
Pin 4 will go to mains –H.T., whilst there'll be an 18V zener between pins 4 and 6 and 6 and 8 of fhe i.c. to provide the low–side and high–side driver–stage supplies.
If you find these connections match up as I've described them (use a DMM 'continuity beep' range to check), then an IR2101 is the correct device to use, replace this, along with both MOSFETs and the zener diodes connected between pins 4 & 6 and pins 6 & 8 of the i.c. – if the diodes are too badly damaged to read, I think 18V 1.3W should be ok – they will both be the same voltage.
Make sure the series capacitor in series with the power transformer primary isn't low in value (if you need to replace it, get an MKP pulse withstanding type!) or o/c., resolder all the transformer and inductor joints associated with all the magnetics on the PCB, replace the mains H.T. bus capacitors (there may be two), and finally check all the secondary side rectifiers for leakage – they'll either be large axial single diodes or dual diodes of the TO-220 type – on dual diodes, the cathode is the common centre leg in most cases!
The BUZ332 is not one of the most efficent MOSFETs, you should be able to find a pair with a good Vds breakdown rating equal or better than the originals, a higher Id and therefore a lower Rds(on), and a total Qg (Gate Charge rating) lower than the originals – I.R. and SGS–Thomson have both brought out excellent modern devices ideal for high–power >75W to >200W smpsu use!
Good luck, and please post back if the above hasn't identified your device, and I'll have another go!
Chris Williams
I would be able to write & draw (after a fashion!) a replacement C.L.I.P. from one of these units if I had one but the absolutely eye-watering prices U.S. sellers are asking for 'em means I can't afford one for a long time yet!
