Author Topic: Lowish resistance between transformer windings  (Read 550 times)
Offline atw58Topic starter
« on: March 17, 2019, 04:44:46 pm »
I'm trying to find the cause of severe ringing on a switching power supply, the transformer has four sets of windings. Resistance is OL between all sets but one (primary to one of the secondary) which reads 1.2M. I've read 1M per 1000V should be the min insulation resistance of wire for motors etc. The max transformer voltage is 400V pp. The rest of the components look good; cap esrs are fine, diodes ok, resistors ok.
Should I disassemble the transformer and fix the low resistance.
Offline shakalnokturn
Re: Lowish resistance between transformer windings
« Reply #1 on: March 17, 2019, 08:09:38 pm »
Was that measured in circuit or off PCB?
