I received an old Iskra 2 channel 20MHz analog oscilloscope from a friend. We have tested it and everything was working correctly. Scope has been working for few hours without any problems.
I didn't have my set of probes so I ordered them of a flebay, and stored scope under the bench.
When probes finally arrived, I've connected them to the scope, pressed the ON button and nothing
Blank screen.
I've tried normal time mode, XY mode, but screen is blank even if I press beam finder.
At first glance I've thought that fault must be somewhere on the HV board. Luckily I have full schematics of the scope.
Oscilloscope is builded as a six board construction. It has two vertical boards, power supply, horizontal and trigger, and HV board. Sixth board is used for interconnecting, and has just a few components.
I almost forgot, there is one more thing that I noticed. When the scope is on for minute or so, and then when turned off and rapidly on again the beam is visible on the screen for about a second.
Power supply seems fine. All rails are bang on except 21V rail which is few volts high. But that rail is unregulated, there is just a rectifier and filter cap, so that seems ok because scope has worked fine before.
I've checked almost all semiconductors on HV board except HV diodes and an opamp in HV stabilizer circuit. They all seems ok.
Even the voltages that go to the cathode tube seems more or less fine.
Cathode voltage is little low (-459V and should be -470V), and focus voltage goes from -460- -389V but should go from -470- -430V. Every other voltage looks fine.
I'm not sure if heater is working properly because glow in the tube is barely visible.
Voltage between one side of a heater and ground is -415V, and between other side and ground is -421V. So voltage between two ends of a heater is about 6, 3V. Are these voltages ok?
I also noticed silent high pitch buzzing. I'm not sure is it coming from the tube or HV board. Probably it is coming from HV transformer.
I've almost reached dead end so I really need your help with this repair.
Any help is greatly appreciated.
P.S. Sorry if my english isn't the best.
