Thank you for the reply.
I had removed CA3 and UA1 to find a short. I still have not found it. The output to ground of the 78L05 measures about 1 Ohm resistance. When I powered it on with the 78L05 in place, the voltage dropped to near zero. With out the 78L05 in place, the input voltage is fine. I am still hunting for the problem. I see the same short conditions around UA20, UA9, QA19, and QA15. I am really hoping that the AD7792 is not bad. Any thoughts on this area would be appreciated.
But there's more. There is a similar short condition around the 3.3V (U2) regulator on the digital side. With U2 removed, the resistance to ground is about 0.2 Ohms. Again, hoping that the STM32 is not bad. I have not started hunting on that side yet.
Could there be a common cause for these conditions? Without a schematic is very hard to figure out.
